Panelview HMI and WonderWare HMI
passwordg
Aug 2011
South Carolina
224
Hello.
I couldn't find a satisfying answer on the Rockwell support pages.
Is the Panelview hardware and Rsview software an alternate HMI to what wonderware intouch offers or are they just completely different products ?
What is "FactoryTalk View ME Station" used for ?
Also, a side question - what is RsLinx needed for ?
They are completely different but similar products. "Factorytalk" which is what Rockwell uses, and "Wonderware" are both graphic packages for operator interface. Panelview is used more for screens, and Wonderware is used on PCs. They each have their pluses and minuses, things one does the other one doesn't. At my current job we use both; Wonderware in the control room, and Panelview in the field, both talking to an RSL5000 PLC.
The "ME Station" is usually used for field terminals, but there is a studio version, and one to run on a PC.
"RSLinx" you'll definitely use for Panelview. Wonderware has its own amazing and confusing driver for the AB PLC. (Once you set it up you can forget it, but the "new guy" approach... is scary!)
Oh yeah... the vendors don't like to talk about each other's products, in public and out loud.
Thanks, that made things very clear.
I'm sorry. I meant to write RSNetWorx not RsLinx. RsLinx I know I definitely cannot do without Rslinx.
When or why do we need RSNETWorx ?
RSNetworx is for diagnostics and configuration of DeviceNET, ControlNET, and EtherNET-IP device networks. I shows what all devices are on a network, which node they are, parameters for each device, and other information pertaining to a network.
Forum users can be more helpful if you explain your requirements. Are you looking for a physical panel type application or something that runs on a PC? Do you want to do control, data collection, what? What kind of PLCs are you connecting to? Do you integrate with other systems or databases? Do you expect to have mobile devices connected? Other requirements are also useful to capture such as: alerting, reporting, historian/trending, etc, etc. Most vendors have some approach to these things.
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
425
I'm trying to use the Create New User button on the HMI so customer has the option to add new users and passwords at the HMI. They dont have...
459
I am working with Allen Bradley CompactLogix PLC. I need its control and monitoring on PanelView HMI and also on computer screen. I have...
1,128
I have been tasked with adding a remote display on top of cabinet to display current speed/RPMs of machine.(using 4-20ma control). Is there a way...
18
4,257
Hi, I have a PVP 1250 with ME station FW 6.0 I would like to upgrade it to ME Station FW10. I downloaded the FW10 from Rockwell site and...
2,337
