Panelview: Maximum 5 trends available
blackbird307
Jun 2015
Winnipeg
59
I discovered that I need to use 7 trends, however I get an error message upon validation that I can only use 5 maximum per program.
I need to trend the following.
- Flow rate
- Primary cell hydrostatic level
- Chemical tank ultrasonic level
- Secondary cells #5 hydrostatic level
- Secondary cells #6 hydrostatic level
- Secondary cells #7 hydrostatic level
- Secondary cells #8 hydrostatic level
I was wondering if I could make one graph share 4 different hydrostatic levels, ie, 5,6,7, and 8. But the downfall is that data from another cell would show up on same graph. How would I do this? I am thinking I may have to use a switch/button in the hmi the toggles between the graphs. But it won't show on the graph which one was being monitored at different time frames.
Also bonus, this is probably my biggest problem right now.
I am having problems with the PLC Micro850 communicating with panelview800 via ethernet. Anyone know which manual that would go into detail about this process? I am using Connected Components Workbench Standard Edition.
Can someone help me please?
For some reason the coil isn't getting energized....
I have figured out the cause of this. There is a really tiny switch on the controller that says "Run - Rem - Prg". For some reason it was flicked into prg.
Trying to figure out what FactoryTalk is talking about her, trying to add a new display in the application and I'm getting this error now...
4,107
Hi all, do anyone know how many panelview plus that I can connect to a single processor L71 using EN2TR. (checked the knowledgebase of Rockwell...
2,629
I'm having a hard time figuring out what I thought would be relatively easy information to find. I simply want to know what is the maximum...
2,435
I'm at a loss here and hoping someone else has seen this: Background: We've got two identical machines on our floor (we'll call them machine A &...
60
103
