Panelview Plus 1000 connection
princedx
Dec 2013
HCM
49
Hi all
pls explant or me can we connect 2 compactlogix controlers to 1 panelview plus 1000 ?
i want to display something of 2 compactlogix controler via Ethernet connection ( use Stratix 8000 switch)
and show me how can we do it ? cause 2 compactlogix have same logic and tag address, so i wonder how panelview 1000 distinguish which tag of first compact logic or second compactlogix
thanks you.
Yes it can be done.
You'll configure the path to each PLC in the RSLinx Enterprise Communication setup.
In your tags the first part of the address (the part in brackets) refers to the device shortcut that you defined in the communication setup.
If you want to get fancy you can hardcode the PLC tag references in your screen object connections (instead of using the tag database). Then use parameter files to change which PLC you're connecting to when you open a screen. This will allow you to use the same screen for both PLC's if you have common data you want to display.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
144
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
2,915
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,864
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
665
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
1,983
