ihatepanelviews
Glad I found you guys and gals, this is my first thread.
I am upgrading a PV+1000 to a PV+1500, and with the new terminal configured and new project dumped into it, will give an error popup that just says "No error message is available" with a yellow triangle with the exclamation point next to the text. This does not occur on startup, but rather 2 minutes to 24 hours after the PV+ is powered up and the application is run.
I have not updated the firmware yet, but it is running 5.10.02.09 and I've got 5.10.16 ready to dump into it. I had read in a previous thread where anything prior to 5.10.11.09 wasn't supported by v20 controllers (which we are running) so I'm thinking that might be it...
However, I am getting the error popup while the PV+ is disconnected from the network (Ethernet) so I don't know if that's the issue. Project and runtime shortcuts are correct (I did not copy from project to runtime because the paths are on different networks so they are different).
I'm kind of at a loss at what to do and any input would be greatly appreciated, thanks!
