Panelview Plus SD card question
Iner
Mar 2010
France
190
Hello,
I have a question, can I use the internal SD card for stocking csv recipe files, or it is reserved for firmware and runtime applications? I know I can use an external SD card, but I wanted to know if the internal sd card could be used too.
What would be the path if it can be used?
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
486
Hello community! I regularly FTP into our PanelView Plus CE devices when they are directly accessible to the network. However, I have some...
1,026
Hello everyone. I would like to set up data logging to an SD card so that my data for a couple of trends is stored even when the screen is...
2,367
Hi, I am setting up a technical manual display page on a PANELVIEW PLUS 1250 HMI, and the page references .pdf files held on an SD card on the...
1,669
Hello, good day. I do you know if it is possible to get a PanelView plus 700 application from the compact flash card inside the device? We are...
2,540
