Panelview Standard DF1 Vs ControlLogix DF1
Tim Ganz
Dec 2010
Dallas, Texas
692
Does anyone know if panelview standard DF1 Vs controlLogix DF1are the same cable / pinout?
I have a 1756-CP3 and trying to use it on a Panelview 1000 standard to download a program using the rs 232 DF1 driver and can't seem to make it work?
Some PanelViews have a serial port strictly for upload/download. Some have a serial port with full DF1 communications. Knowing which PV you have will help identify what type of port you have. Although, if your PV has another comms network, then the serial port is an upload download port. If it only has a serial port and no other comms then it is a DF1 port.
To use the upload download port requires a standard RS232 cable. For full DF1 with your controller you want a crossover cable like the CP3. My memory on these older PV terminals is a bit hazy, so someone here may have additional details.
OG
I seem to remember that it used a straight pinned cable with the wrong gender at one end.
Otherwise you can plug the PLC end of the cable into your pooter directly.
I keep a small handful of mini gender changers and null modem adapters in the ziplock back with my USB to serial converter just for such cases as these. Just the other day, I needed to upload from an old PV standard and ended up stacking three of them on the end of my converter to get the right gender and crossed over and back to get RSLinx to see it. If I simply had a female to female gender changer without the crossover in that ziplock back I would have been good to go, but I probably left that little nugget permanently installed somewhere. I took this picture so I would have the model number for future reference while I was waiting on the transfer process.
Had an interesting experience this morning. An old Panelview 600, 2711-K6C5X series B to be precise, comes up as error 32. Unfortunately it...
211
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
643
Good evening. I am trying to get a SLC 5/03 connected to a Panelview Plus 7 Standard using a Moxa Mgate EIP3170 and I am not having much luck. I...
525
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
679
Hello All. I have an interesting one for you. I have a brand new Panelview 600 Standard 2711-K6C20 and I'd like to get it to talk to an L81E...
2,031
