PanelView Upload over DH+
cntrlfrk
Feb 2006
Nebraska
244
I am attempting to upload a PanelView 1000G via an ethernet gateway (1756-ENET/B) and a DataHighway module (1756-DHRIO/B) and I get an error: "Improper attempt to use a 1756-DHRIO module port-to-port pass-through path"
I can browse to it find in the PanelView software (PanelBuilder32--V3.81) fine, but continue to get the error.
I don't do the PV900's or PV1000's very often, is this even possible, or do I need to do a direct serial connection?
I had the same problem some time ago.
Using the Clogix platform, I had a DH+/RIO card in the rack that I had to use, with a PCMCIA card and DH+ cable.
There was quite a bit of information on this subject, and some tech notes that I posted at the time.
I will try to find them....
Thank you much.
I had actually just modified my searches and found that same thread and several others.
I think this will get me there.
Thanks again
One last question.
When I download the routing table to the DHRIO card, will I lose DH communications? I have several other PV's on here and PLC's as well.
Just don't need any more stress today if I knock the plant down. ;)
Hello, I have a machine with a 1756-L72 Controllogix PLC and 1756-EN2T network card, and PanelView Plus 7 HMI. I am using RSLogix V20.05.00...
924
Hi all, I have a 2711R-T7T running an application without a shutdown button in the current program. I've looked at all the manuals and can not...
1,269
I have a machine that was powered off for repairs, when powered back on the Panelview fails to upload the tag database from the PLC. Its a...
1,547
Hi All, I have an issue trying to upload a program from an existing Panelview 1000 terminal that I was hoping I might be able to get some help...
2,228
Hello, anyone had a similar experience? A customer has an old panelview600, it is faulted, but is communicating and they desperately need to...
3,766
