PanelView300 Comm to Momentum
solehm
Jan 2006
ca
We have a customer that wants to upgrade their existing system.
Currently, they have a PV300 communicating to SLC 5/03 using DF1 protocol. They want to replace the SLC with a Modicon Momentum PLC (for maintenance reason: they have a lot more Momentum PLCs than SLCs).
The question is: Can the existing PV300 communicate the Momentum? If so, what protocol can I use? Will we need to buy some type of converter in order for them to communicate? How difficult/easy will it to implement this modification? How will this affect the tags' addressings?
Please help.
First thing is what type of Momentum?
Does it have a comm adaptor, and if so, what type?
The only common protocol between these two devices that I can find is Devicenet. Tha part # for the DeviceNet-capable PV300 is a 2711-K3A10 and the associated Momentum DeviceNet Comm adaptor is part # 170LNT71000. It first between the IO base and the CPU.
Momentum part #: 171 CCC 980 30
It has an ethernet port.
Comm adaptor: 170 PNT 110 20, MB+ option adaptor
I there a DF-1 to ethernet converter I can use?
Also, how will this affect the PLC addressing? SLC use BX/XX, NX:X, etc while momentum use 00000X, 40000X, etc.
Thanks, SLC Integrator.
How about Panelview tag addressing issues? Can I just covert them from BX:X/X to 000XX, etc?
Im not sure how the DeviceNet part work in Momentum, having never done one. I guess once you map the Modbus address to the devicenet tag then you just point the PV at that address in the IO section of Panelbuilder.
Hi, I am trying to communicate Panel view 300 with Micrologix1500 LRP. PLC: Allen Bradley Micrologix1500 LRP HMI: Panel view 300 CAT#...
1,982
Hello to all I've received a new panelview300 IHM.I was trying to enter the menu Config; but it prompts me to enter a password. Please can someone...
14,753
Have a Micrologix 1500. Trying to download to a Panelview 300 (2711-K3A5L1) using a 1761-CBL-PM02. Is this possible?
2,345
Hi, I have a Panelview300 micro and not able to get to the configuration menu. Since the left and right button was programmed as function key...
4,175
iam new at this, so be nice,,,lol can anyone tell me if the 300 micro can control a timer, and can it change the a fifu outpout bit and if so how...
3,875
