PanelView_Blues
Jul 2005
Manchester
I have a 2711-T10C20 Panelview 1000, tried to connect via Ethernet...no go. The Panelview is connected to ABs 9300-RADES Modem, the other connection goes into Mencom Ethernet connection and Logix 5000 rack. If I connect thru the Mencom, I can see and talk to the Logix 5000, I cannot however talk to the Panelview. I am using Panelbuilder32. The Panelview and Logix 5000 talk without issue. I was under the impression that I could use the RS-232 port on the Panelview, and that the printer portion was switchable. I tried thru RS-232 as well with a straight and null connection, no go as well. Any help would be greatly appreciated. RSLinx Lite 2.42 Build 18
I found it is easier to connect with a ethernet switch instead of 9300-rades. You could use any connect the panelview,logix 5000, and the 9300-rades to the switch and it should work fairly easy.
Pat
I’m running short on time to complete this project (retirement looming), so thought I’d ask here hopefully save me some research time. I’m...
133
196
Replaced overlay and glass in HMI but now I can not calibrate the touch screen any suggestions.
91
i have 2 backups: *.PVC and *.pvd file types thanks in advance for any help
164
94
