Parameter programming in Variable Speed Drive
If you post your phone number maybe I can Text Message you the parameters! (in text message format such as : tell plz, etc).
It may be hard to read but I"m sure you can manage as I already have read your mind and will give you all the answers.
maybe its the actual inverter on the forum, looking for parameters.
That's a thought. It's BOUND to happen SOMEDAY. WE provide the comms..... I suppose we should be flattered that this evolutionary break-through would seek out OUR humble forum.......
However if the VFD and the comms are smart enough to get here then should they not be able to get to the manual which is stored in PDF format?
Hmmmm Open pod bay doors Hal,,,,-- ?????
Dan Bentler
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
315
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
82
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
459
Hi Everyone, I am trying to add a constant value (such as a string) into the parameter file. I put the string in " " but it does not work. would...
201
I confess, I always have a little frustration trying to accomplish tasks in CCW that are simple in Studio 5000. My latest task is with timers...
487
