Parker ssd cable & automation direct D2 cable
controlled
Nov 2005
bowmanville
419
Does anyone know the pinouts for a parker ssd cable. Its a standard 9 pin d shell on 1 end, and a 4 pin rj style connector on the other end. It looks exactly the same as the D2 cable from automation direct. I have the automation direct cable, but now have to make some changes to a parker ssd drive. Im hoping i can use the automation direct cable.
Dear all, we have a couple of SSD 637 servo drives that need to communicate trough easyrider. On the parker website you can download easyrider...
515
Hy everyone, I have Parker DC Drive (590+). in ints manual there is mentioned about P3 port which is based on (RS-232) communication. I want to...
908
What is the best velocity command resolution I can hope to get with a Parker/SSD 890 drive receiving a velocity command from a plc over...
1,593
Does anybody have any knowledge of oddities with the SSD 890 AC Drives? Both compact/bookshelf, and monstrous stand alone ones have the habit of...
4,890
I'm working with AC10 Drive 1KW 3x400V. I configured it running in Torque Control Mode. But it's not work. The speed's not smooth, when I increase...
1,337
