Pass a tag instead of value in PlantPAx AnalogEdit
Jul 2007
Kiruna
600
When I call the Plantpax (RA-BAS) Common-AnalogEdit faceplate I pass in a tag to be written to, a min and a max value as follows:
Display (RA-BAS) Common-AnalogEdit /T{[Shortcut]Process_Setpoints[33]},0,50,Ramp_time_(secs)
Instead of a min and max value I would like to pass tags containing these values in. Anyone know how to accomplise this?
Anyone?
I have the same question.
No Work:
Display "(ra-bas) common-analogedit" /T {#101},{#500},{#501}
Works:
Display "(ra-bas) common-analogedit" /T {#101},0,50
As far as I can tell, this means I have to hard code them and can not use them in a global object. WTF???
You definitely can. Look up the usage of placing a tag between two $.
Those cheeky *******s!
This works if, you use a number like "0" in the global object parameters or if you use a tag with $ bookends:
Global object parameters
#500 = 0 Yes
#500 = CONSTANTS\00 No
#500 = $CONSTANTS\00$ Yes
#500 = $CONSTANTS\01$,$CONSTANTS\01$ Yes!
Hello: I am currently converting an old panelmate application over to a PV+ I have a large number of popup controls that all look/act the same...
6,542
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
176
So I'm having issues with a certain rung and one of my coworkers mentioned it may not allow the signal past the latch coil. For example in the...
27
3,759
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,082
I've been given a line that has several sysmac c200Hx PLCs. The First station Im trying to wrap my head around has a NS8 HMI. I'm using Cx-one...
752
