Pass/control bits to/from a webserver.
bobbysuavey
Nov 2016
Missouri
Hello!
I have a 1768-ENBT/A connected to a CompactLogix with a DC in and relay out card. I'm trying to hook this up in my garage (control the door, lights, etc.), and am wanting to be able to view the status of the bits and turn bits on and off via a web interface running on a webserver on the same local network. Basically I want a webpage with a button that says "GARAGE DOOR" that you can click, and have it turn on an output that opens the garage door.
I have some experience with PLC's, but any communication like this is new to me. I've looked at network traffic with Wireshark and have looked at the CIP messages, but can't make much sense of it. Basically I'm looking to see if this can be done at all, and if so, some direction to point me in.
Thanks for any help!
Hello,
Yes it can be done.
PeakHMI can accomplish the task.
You can try the demo and verify it all works for you.
Contact support if you need any help.
Hello all, I’m doing my first project with bypass control of a VFD and wanted you opinion on the control schematic. I’m still not sure about how...
4,174
Hello does any one know or have a source file for a high-pass filter for S7 to help with high speed position control over-shot Thanks in...
4,518
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
182
So I'm having issues with a certain rung and one of my coworkers mentioned it may not allow the signal past the latch coil. For example in the...
27
3,766
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,093
