Pass REAL to INT
vib
May 2022
spain
Hello I have a question about SCL
if I have a real value
like
valor: INT
I would do
valor : = 1.5
Or this trhow me an error?
How can I save only the 1 of the 1.5 in a INT type?
Thanks,
Bless for this web, it's amazing.
You have not stated the platform (PLC you are using) you really need to use one of the in-built functions like REAL_TO_INT. it will depend on the PLC & it's functions there are some others like TRUNC but be careful, some conversion routines return 32 bit integers not 16.
Oh,
then you have to use this special function
ok
thanks
You don't have to use a special function. it will depend on what plc you use and which language otions you have. The following code extract is taken from Siemens S7 STL language
Code:
mb02: L     #rTemp
      +R                                // Add offset to previous value
      L     1.000000e+004               // Check for max
      >R
      JC    out
      TAK
out:  RND
      T     #iRewindSpeed10k            // Output the value
Read your post a little more, not sure what you are trying to do but you have an integer variable & trying to assign a real value is that correct, or is the real value from some other variable that is a real & you are trying to write it to an integer variable ?
If the value is fixed i.e. Valor:= 1.5 will not work but Valor:= 1 will.
Or if Valor is a real
for example:
Valor: releal;
My_Int: Integer;
Valor := 1.5;
REAL_TO_INT [Valor, My_Int];
But if as Manglemender suggests & it is Siemens then follow his suggestion.
Or RND[Valor, My_Int]; however, this may return a 32 bit long integer not a standard integer;
Reading the 1st post again, I think that this is the actual question
If you want to convert a REAL to an INT and cutting off the fractional part, then use TRUNC.
edit:
To take a REAL, cut off the fractional part, and place in an INT you have to do
valor := DINT_TO_INT(TRUNC(1.5)) ;
If you want to convert a REAL to an INT using normal rounding, then use REAL_TO_INT. Notice, that will round 1.5 into 2.
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
188
So I'm having issues with a certain rung and one of my coworkers mentioned it may not allow the signal past the latch coil. For example in the...
27
3,772
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,100
I've been given a line that has several sysmac c200Hx PLCs. The First station Im trying to wrap my head around has a NS8 HMI. I'm using Cx-one...
753
See image below. Look at line 95. I tested all data type, but none of them works. https://ibb.co/H2Csr15 See this. TEMPDATA2 is used only...
2,712
