passing parameter in rsview se
volga
Mar 2007
surat, gujarat
hi
how can i pass pump 'run stop trip' hmi tags to multiple pump objects in graphic. i hv 26 pump in 1 graphic and for each pump i have to define 5 animation so how can i pass parameters to pumps. how to run parameter file at startup of particular page.
Just create a parameter file for each pump, when you open the display. The actual command would be "Display MyPumpGrapic /PMyParameterFileName"
If your tags are well organized, it's very easy...
Say you have folders in the HMI Tag folder like this:
Pumps/Pump1/Run_PB
Pumps/Pump1/Stop_PB
Pumps/Pump1/Trip_ST
Pumps/Pump2/Run_PB
Pumps/Pump2/Stop_PB
Pumps/Pump2/Trip_ST
etc...
In the graphic display for the start button, make the tag connection "Pumps/#1/Run_PB", the stop button should be "Pumps/#1/Stop_PB" etc.
Now, the parameter file for pump 1 just needs one definition line:
#1=Pump1
THe parameter file for pump 2 would just be the same, just:
#1=Pump2
I inherited a project in which a ME application displays process measurements (temp, pressure, flow, etc) on a PanelView Plus display. The data...
505
Hi guys. Sorry for the dumb question but I am still new. I have learned to pass Parameters using an HMI tag so far. Can I write directly to the...
930
Hi guys, A dumb question, but is it possible to pass values to tags using parameter files in Ftview SE ver 11? TIA
1,475
Is there anyway to pass a parameter file without using a Go To Screen button in FactoryTalk View ME? I am currently using multiple Go-To buttons...
1,642
Hello I am trying to have one screen that has one trend, that I can have an operator select what tag to trend. IE I am trending a bit shift, a...
1,174
