passive analog card for slc 500?
peter764
Oct 2008
Maine
35
I'm working with an AB slick 500. It's running a RO system for the boiler room. I'm trying to interface with a transar system so they can monitor the operation and recommend maint. The problem is that I'm trying to put a 4 to 20 ma signal into an input in their board. It had 3 connections one said +24, and the other two were supposed to be passive with a + and - connection.
So I hooked it up to the the passive connections and ended up burning up the board input twice!!
Does allen Bradley make a sinking or passive 4 to 20 ma output card or some sort of isolation board so I can interconnect the two?
I haven't done well in searching this out? the transar board manufacturer finally said abosolutely no voltage to their board......seems they need to update their schematics? Oh and a factory tech hooked up my connections even after he saw the voltage coming off the analog output......
Thanks for you help
Can you provide a link to your "transar system". (manuals?)
Did it work when the tech did this?
Again and old thread. They are probably 2 wire 485 ModBus protocol? Too much info in a Trasar to get out via 4-20ma.
Hi everyone, I have a new (for me) situation with a new job I am working on. I am using the output channel of a 1769-IF4FXOF2F card to send a...
2,630
Hi, I have a device which is giving out a 4 -20mA signal but the ADC's on the PLC channel do not match. The supplier is saying the channel needs...
761
Can you wire a 1756IF8 analog input card for passive and active instruments at the same time or do they have to be separated. Such as wire 1 card...
4,982
My basic question is, what is a passive tap on an RS-232 line, and what is a derivation cable? It sounds like a passive tap would just be wires...
2,912
Dear Guys, I was thinking is there any possibility of making our automation service business to be passive. such that even if we are not working...
3,904
