PC to PLC:)
theripley
Jul 2008
laguna
545
hi there!
is there a way to communicate PC wit PLC? :eek:
hmm, i would be needing signals from PC (visual basic program) to work wit a PLC unit..im only familiar wit PLC..I do not have any idea regarding this application..
any help would be greatly appreciated :geek:
http://www.ingeardrivers.com/
This company sells ActiveX modules that allow you to communicate with some PLCs via Visual Basic.
Alternatively, you can buy an OPC Server for your brand of PLC and build a Visual Basic program that accesses the PLC through the OPC server. This is detailed in the following link.
http://zone.ni.com/devzone/cda/tut/p/id/3259
A third option would be to research the company that provides your PLC to see if they sell a pre-made product for this purpose. For example, Mitsubishi sells a product called MX Components that is intended for this type of application.
If you decide to go with the OPC alternative check out Kepware. They have a great OPC server (lots of drivers) and a .Net API called Client Ace, Client Ace helps you develop OPC Clients (VB.Net, C# or visual C++) easy. There are also lots of code examples. You can download and try them both (2 hours demo for the server) at http://www.kepware.com
I have used them both and it works great...
Regards
Edmund
Monkeyhead,
Tnx for the options. I guess il go with your latter choice. I hope il find a good & easy to use hardware.
Edmund,
Tnx, il try to see if we have kepware distributor here in our country. Nonetheless, i have read that OMRON allows PC to PLC interface via CJ1M..Il see if there hardware works for my application
What PLCs are you using? There are several open source drivers and samples that are free. Check www.sourceforge.net
Also Google the protocol if you know it, such as "DF1 open source"
You mentioned Omron, their Host Link protocol is very simple and can be implemented in VB with very little code. I may have some VB.NET samples from a project I did several years ago.
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
139
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
74
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
90
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
59
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
98
