PCI serial port success?
Apr 2002
Just a bit northeast of nowhere
1,117
So I had an idea I thought was pretty clever. Since we have alot of legacy DOS equipment to support and laptops don't come with serial ports these days, we'd get a desktop and a PCI card with serial ports built in. Set up dual-boot to 6.22 and rock on. Maybe not the most portable thing in the world, but functional.
Only issue, the card itself. I'm considering the PCI1S550 from StarTech
http://www.startech.com/Cards-Adapters/Serial-Cards-Adapters/1-Port-16550-Serial-PCI-Card~PCI1S550
It has dos drivers and claims to be compatible, but of all the online comments about it, I found only one referencing DOS - everybody else is using it to connect old printers and modems under Win XP.
Has anybody used such a setup with success? Not nescessarily with this card, but something similiar?
Thanks!
TM
Hi TM,
Yes I have done it several times... but most desktops still come with serial ports so I have just used the supplied serial port
I also run DosBox (virtual DOS) and so far has worked great, I have done this for several customers
It's been a few years, but we used a Rocketport PCI to serial adapter to get multiple serial ports on a scada PC. I remember it being very solid and highly recommended at that time.
It doesn't list DOS drivers, but they are there if you drill into the support "tree".
You'll have to google it, since the forum doesn't like the text in the mfg. dot com name.
All, I am missing a driver for the serial card (PCI) and all the information I have on it is "KEC 222N". I've search high and low for this...
3,630
I got SST Profibus Configuration tool to see my VersaMax IO but Proficy is acting like I didn’t install it right. I may need to move license off...
569
Anyone out there know of a new desktop (full size workstation) PC that will accept a PCI card? :huh:
1,816
Dear Jesper, It seems communicating with that 416-2 PCI card type PLC was easier than I thought. I changed the name of the computer to...
1,797
Dears, I've Industrial computer containing applicom PCI Board 32K which connecting to S7-300 PLC. The hard disk of the computer has fault and...
2,376
