PCS7/WinCC and CP1613
Jun 2005
Montreal, Quebec
252
I have a customer running PCS7 V5.0 on Windows 2000. They are looking to replace several of their computers. For the majority of the equipment we have simply loaded Windows 2000 within a virtual machine and all is well.
However, we have 4 servers (2 redundant pairs) and 2 standalone WinCC machines which have CP1613's installed because there are 3 S7-417h PLC's in the system. Virtual machine is good at passing through a generic TCP/IP adapter, but we have not been able to successfully configure a CP1613 in the host operating system and pass through the connection to the virtual machine.
Has anyone run across this before and come up with a solution?
The customer will be doing a PCS7 upgrade within a a year or two, but until then they need a solution from a maintenance perspective.
Any ideas or solutions are welcome.
Your a brave soul.
The CP1613 must be used for redundant WinCC/H connections. Also Redconnect is the software for this. I dont know anyone thats even thought about trying it on a VM ;)
Don't forget you will also need serial comm connection for sync between Red Server PC's. As said before...brave sole. Bite the bullet and upgrade with appropriate OS support.
V6 & V7 are so much better.
Hey folks... I've been thrown into the deep end of a dodgy pool. A life line would be appreciated. Our one and only resident PCS7 knowledgable...
4,067
Hi, In my Plant i have PCS7 (WinCC V6.0+SP4) System.( one ES/OS and One OS )... I need Shift Report (every 8 Hours ) using VBS script or Default...
2,254
Hi all, Do you know what are following applications (possible to activate in WinCC - Computer Properties - Startup) responsible for ...
1,892
How to do this right? Is this possible in general? When OP is integrated in PCS7-project (v. 7.1) problem with OS occurs: 1 In NetPro - "...
6,719
We have a multi node PCS7 installation and lately we had a problem when we downloaded a new project to one of Wincc OSs . WinCC can only...
1,481
