penetrating temperature instrument
May 2007
giza
154
Hello
I am looking for Laser or Infra-red temperature sensor to put in our stores
stores containing coal piles "as shown in attachment".
my concern is that I need to measure the temperature inside the pile "no more than 1 meter" , not need the temperature of the surface
Any one know brand of sensor can help me?
thank you for helping
With an infrared sensor you can only know the temperature of the outside of the pile.
To read the temperature at one meter depth that meter should be transparent to infrared radiation and it is clear that this does not happen.
About a laser, as far as I know, it does not measure temperatures
Sorry, I can't help. But I'm curious- is this to make sure there isn't smoldering going on inside the pile for fire prevention?
You might check out this site for links to research on coal stock pile fire mitigation:
https://www.researchgate.net/post/How_to_mitigate_spontaneous_combustion_in_Coal_stockpiles
Thermal imaging is costly and but has minimal maintenance aspects compared to contact thermometry with thermocouples, which would be labor and maintenance intensive.
I'm not even sure whether a hefty 3/8" diameter sheathed thermocouple can penetrate 1 meter or 3 feet into a pile of coal without damage to the element.
Then there's the problem of getting the signal to where it can analyzed - lots of armored thermocouple extension cable.
There are battery powered wireless temperature transmitters (Banner Engineering).
Hello Folks, I have two watlow controllers that have two J-type thermocouples connected to two heating block on a sealing equipment. The...
98
117
Hi!! I'm looking for Temperature rise calculation software from Rockwell, I just download "Product selection toolbox 2022" but this software is...
254
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
719
I am looking for temperature/humidity sensor recommendations. Would like the sensor to display temp and humidity. Need to connect to a Contrologix...
262
