pf755 speedreference setting
cctthh
May 2021
korea
hi i have a problem When running pf755 START UP WIZARD for a directional TEST, JOG mode operates at the input frequency value, but when you enter the value in SPEED REFERENCE and start it by pressing the green button, the input frequency value does not appear and the motor does not work. I'm going to use PTP mode SPEED REFERENCE using Ethernet (Par930 value is 877) I'd appreciate it if you could teach me which parameters should be set or bits should be set in plc logic to control the speed in plclogic over Ethernet.
Of course, we have now added modules using the logix5000 eds, and we have completed setting parameters through the Drive Executive startup wizard. (P545 chose Ethernet as 877) In Logix5000, the rest work normally, such as forward, backward commands, jog operation, and encoder value verification, but it sends reference values through Logix's Output tag, but the motor does not seem to work because it is not reflected. I also checked the programming manual. The current motor control mode is induction fv mode. The ptp setting also followed the manual. If you know what parameters you need to set to control the speed and use ptp mode on the logix5000, let me know, and I will compare them to the settings I made.
Hi all I have tried setting up the adc on a existing pf755 with studio 32 And want the firmware to update too the firmware on the plc is 12.01...
37
Hi, I am having issues matching a 50HP submersible pump w/ a PF755 VFD (480V 3-Phase, 65(ND)/52(HD)). The failures occur at the static...
995
I have a relatively small network but I am having some issues with PowerFlex 755 drives (using the native ethernet card) Faulting with the F926...
222
I am having some trouble understanding what the break frequency is on a pf755. This is set in parameter 63. Rockwells description reads like the...
795
We have a Powerflex 755 set up for motion control that is giving us a overtemperature alarm. We swapped out the drive for one of our new spares...
2,130
