PG/PC settings EMPTY - Just listing None
DanC2188
May 2013
England
Does anybody know how I can get my PG/ PC settings list back?
It now just lists 'None' (please see the attached screenshot) I have tried to reinstall and tried to repair this as well and nothing has worked.
Any assistance will be greatly appreciated!
Not sure what software you are using... but I have had it happen several times for TIA and Step7, I had to uninstall and reinstall. My MicroWin turned into German... lucky I know it enough that I can just use it anyway, I think these come from Windows updates
I took information from this link, but modified the steps a little:
https://support.industry.siemens.com/tf/ww/en/posts/problem-with-set-pg-pc/140028?page=0&pageSize=10
Go to C:\ProgramData\Siemens\Automation\Simatic OAM\data\LogDevices
Rename the data folder to data_old
Run SIMATIC Manager as Administrator (right-click, run as Administrator)
It should rebuild the Set PC/PC interface device database
Thank you very much for your help mate! The only thing I found that differed from this slightly was that I needed to create the folder 'data_old' as well as the folder 'data' for this to work. No idea why but thank you for your help!
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
142
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
964
Hello. I cannot change the SendClock settings for a PROFINET IO device. I need to slow down the CODESYS PROFINET IO controller. What am I doing...
206
Hey all, I wanted to discuss an issue with achieving a constant flow rate of around 10 GPM on a glycol circulation pumps in a 1200-1300 PSI...
961
Hello, I am currently taking a course on plc programming and in the course rslogix 500 is being used. I am however having a problem since it keeps...
1,720
