Photoeye Mount
DavidBartel
Feb 2010
Conyers, GA
I know this is not really a PLC question but I'm guessing a good number of you must deal with the other side of the equation (The electrical devices).
I'm looking for a photoeye mount for an 18mm photoeye. It’s basically a couple of tubes or rods (about 1/4" dia) that are clamped together perpendicular to each other with a piece of molded plastic. On one tube will be a piece of molded plastic for the photoeye and the other will have a mounting base.
I can’t seem to find the company that makes these. I have seen them on packaging machinery and scales and so on.
The only picture I have does not show the whole assembly but I'm hoping it will catch someone’s eye that can point me in the right direction.
Thanks’
Balluff sells them for their product line, no reason why they wouldn't work on anything else though.
Link to pdf
The rod and clamp system starts around page 37. In fact that one in your picture looks like the Balluff.
Im looking to replace a retroreflective Photoeye with a throughbeam or light curtain. The retroreflective eye is causing some issues with...
4,146
Hi all, this is my first post, I just got a gradute job, but there was one question at the interview I could not answer, I am curious to know if...
1,827
Good morning all. Does anybody know of a good photoeye, w/PNP output for a sinking input to the PLC to use for detecting clear packing tape at a...
1,672
I have a PE with 5 wires...L1+, L1-, com, n.c., and n.o. My question is should I connect the com to the L1- terminal and then run my n.c. or n.o...
2,991
I want to stop a process with two motors when an object is detected. Is it possible to just wire the PE output to the starter coil ( vs. running...
4,152
