pick and place application
alagesan2704
Nov 2013
hosur
I am designing a 2 YZ axis pick and place system for stacking products in 3 x 3 matrix. The user will select the number of rows, columns and height of the stack.
I am planning to use worm geared ashynchronous motor for this application with brakes & encoder. We are planning to use VFD for controlling the pick and place.
I need suggestion in selecting the right control system.
1.Should the encoder feedback directly connected to PLC
2.What is the configuration of PLC to be selected
3.Do we require motion cards for this application
4.Programming of PLC, any advance instruction similar to robot programming is available?
the common process for this is servo driven
you need to look at your production speed before the design any further.
If we want to stick to basic definition we have motor, encoder (position feedback) and PLC, so we have motion controller with servo.
But the real question is speed of process, required moment and precision. If you tell us that, we can be very precise with answer.
Best regards,
Vuckovic Goran.
Hi everyone Can anyone help me to understand the ladder logic of pick and place system of ITS PLC atg edition ? thank you
2,246
Hello everyone :) I have to use Its PLC Atg Edition to create the ladder diagram for the pick and place system. Can you guys give me some ideas...
1,898
we have a pick and place setup that consists of a Y-axis mast that moves back and forth on a horizontal carriage x-axis. The mast hangs on, and...
3,220
hi everyone, I'm new with plc, and am trying to connect cpu 313c with pc via MPI usb cable. Plc is set to run a FESTO pick and place station. I...
4,340
Hi Guys, I have an application i hope someone can help with. First of all, all air cylinders are controlled by double acting valves. I have...
10,294
