PID Controllers with Time-Proportion Control
rajy2r
Nov 2006
Canada
167
I am looking for a PID Controller that can do Time Proportion Control (Pulse actuator with 25 Sec open close time).
I have used a RedLion PXU for an actuator with 4-20mA control signal, but i am hoping to find an offering where i can essentially use the same line of controllers for 4-20mA output or Time Proportion Output, so that the panel drawings and settings are essentially the same except for the part number change and the actuator style change.
Would appreciate your response.
PID controllers with a binary output
- electromechanical relay
- solid state relay
- transistor open collector output
have time proportioning PID.
Hello, Do you know what is the difference between the PID controllers PIDFF, PID1 and PIDP1 in a Schneider PLC? I have to modify a PLC program...
1,745
Hi everyone, Im planning to replace existing temperature controllers with a PLC. The setup will be aprox 8 thermocuples, and the outputs are 8...
5,384
Hello hai to everybody . my name is M.S.N.Rao. i am working as a plc programmer. i have some doubts regarding PID loops. if any one have...
2,543
3,708
irfan
I
86
