PID in S7
Ashwini Sahoo
Nov 2012
Faridabad
33
I am very new in PID as well as in simatic.I have a project where i have to use PID loop.
The objective is to maintain the temp. of a tank.The tank has to reach to a temp. of 155 C within 14 minutes in manner that the graph between time & temp. should be linear. The highest temp. to be maintain for next 90 minutes.
There is a valve from where hot steam is coming to maintain the temp & as well as the pressure.The valve has to be open & close to maintain the temp. according to PID loop.
I have to use fb 41,fb 42 & call that in ob 35
prefer me some manual/pdf
PLZ HELP!!!
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
78
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
147
106
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
109
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
650
