PID (ISA) configration parameters
jcp
Feb 2010
Multan
369
HI experts;
I have a programme which develop in Ge 90-30 series with CPU 352.
I read the logic for guidline. I see in the PID (ISA) he starts address from %R2500.
Now the programmer move the 0000 when shutdown occur to the %R2515,2516 and 2517 which are INternal SP,CV and PV respectively. While in the documentation these are declared non configrable.
Please guide me why he used what's idea behind this?
Regards
HI experts;
Regards
Is the control output analog (ie 4-20mA or 0-10VDC) or digital (ie an ouput getting PWM'd)?
The programmer may have zero'd them out in the event of a processing fault where he wanted to make sure that the output value was stuck on at a high level. Generally speaking the CV and PV will not be manually maninupulated, but if you stop executing the PID code then the controller will not overwrite your manually set values.
Dear Fellows; Good day. Here i share two images one is PLC Sweep Time control and Monitor Screen and the other one PID Control Screen. First i...
256
Hi Friends; Scanning time is 16 ms for GE 90-30 series CPU 352. I am confuse to set the sample time for the PID. If i set it 20 ms then what...
20
6,213
Hi Experts? I am very greatful to this site who helps me on each steps but now i am stuck to tune up the PID setting of the gas turbine fuel. I...
3,103
Hi friends; I set the parameters of PID loop in GE 90-30 series CPU 352. I start the address from R1010 to 1050. I confirm that no register...
3,481
Hi experts; Good day. I attach an image which shows the PID setting. In yellow circle i want to understand what is that and its effect if i change...
1,701
