pid level control
steff007
Oct 2011
capetoen
hey guys i need help urgently i am in need to program aa s7 300 plc siemams and here is the requirements:
You are required to program the plc to implement automatic or manual PID level control on level control rig. You required to implement level control incorporating the following:
Differential Pressure Meter
Variable Speed Drive (VSD)
PLC with analog I/O
Electronic Chart recorder.
You will be required to configure the VSD.
Auto/Manual control must be via a on/off switch connected to the PLC.
In manual mode the VSD must be controlled via a additional analog input on the PLC.
Chart recorder must display the liquid level also coupled to the PLC.
Use a variable table to display the following:
• Liquid Level
• Auto/Manual mode
• VSD analog input signal
can any one help in terms of how i should go about in solviong this problem i am a rookie
This appears to be a student problem. Most guys here do this for a living, so we are unlikely to do the programming for you. Here are some hints:
Make an I/O list for the PLC. This often helps programming because you have to think about what the PLC is responding to and what it is manipulating. Think about the function of each device.
Think about how you would control the system by hand.
Write a simple description of logic in plain language - as if you were explaining to a buddy how it works - in detail. "First I check the level, then I compare it to setpoint, .......
Then start programming with something simple like the chart recorder echoing the input. This eliminates the intimidation of the blank page (or screen).
Enjoy
thans alot tom ... appreciate it. u mind me emailing u sum more questions as i go along, coz im strugling between which pid function to use wherether the fb41 or fb58. pls not it is an continuous automatic control... anthor q would be how do i connect up the recorder does it com from the outputs
Take a look at the standaard blok for continius control (FB41). This blok does a lot off things you require.
How can I connect PID Output to a valve. In ladder logic program is there any logic do I want to add between valve and PID? PV=SP What will be the...
429
Hi, I started off my career in PLC programming doing water/wastewater on AB around 20 years ago, but then moved overseas a few years later and...
57
12,121
Have a level control application that consists of a small chamber relative to the size of the incoming and outgoing pumps. I've done this type of...
3,620
Good morning, I have a question and I don't really know what you would call this.... I have 2 tanks which I need to control the level or froth...
7,822
Hi friends I have a L24ER-QBFC1B in a Level Control that you can see in the picture. Tank1 is the process tank. Level sensor is the process...
3,072
