PID Loops
Feb 2004
84
Hi everyone,
I am trying to figure out a total understanding of the PID closed loop system. I have read over and over all the info I can find on this a few times in the past, and would really like to set up a closed loop system. I have asked in my instructors in the advanced plc classes if we were learning PID's and to my surprise we were not. (only reading about them). I come across these systems all the time but do not fully understand all of it enough to set a system up. Does anyone have any suggestions to research more into this. I also over the weekend had to change target values for a batch mixer and would like to understand 100% the program for it is a very large program.
Try the ISA website or google PID there's lots of info out there as well a few good post here. I recomend understanding the theroy of PID first then how YOUR plc handles the instruction.
good luck, Steve
The wikipedia article isn't bad:
http://en.wikipedia.org/wiki/PID_controller
Fundamentally proportional control says that if a measured parameter, say the temperature of your shower water, isn't right then you have to adjust an output, the faucet position. The farther off the temp is the more you crank the faucet. You keep tweaking until the temp is just right - that's integral. And from experience you know that the water will keep warming up after you stop cranking the faucet so you stop short if it is getting warmer quick enough - that's derivative.
Hey All, I am working on the programming to maintain level and pressure in a 80 gallon surge tank. This tank feeds fillers that fill either 2.5...
1,557
Hi guys! It seems to me that PID loops with feed forward are underutilized. Maybe it's just me but I think almost every loop would work better...
2,756
I have a need to control the speed of a pump using two different control scenarios. The hardware is an AB CompactLogix with Studio5000 V30...
47
16,221
Hi, I am new to Eaton ELC Soft. I have a background with Allan Bradley plcs but this seems to be set as if from 1950. It seems to be powerful...
1,988
Hi A few weeks back, I purchased PLCs.net Newsletter Tips Compilation 2002-2012 (good stuff) Noticed lately in the recent issues a series...
2,306
