PID n00b
i_am_bs
Oct 2011
Saskatoon, Saskatchewan
Hi all,
Here is my situation:
I have a mining machine which has two large cutting heads. The machine is on tracks which are hydraulically driven (4-20mA proportional solenoids). Basically if the operator drives the tracks too hard, the motors driving the cutting heads will exceed their full-load current.
I'm taking a moving average of the head currents and then selecting the maximum of the two. If this maximum average exceeds the full-load current of the motor, I would like to scale back the output to both proportional valves.
I'm pretty sure that I would use a PID to do this but I've never used one before so I'm looking for a little help on getting started.
I'm using Logix5000 / control logix L61 controller.
Thanks in advance!
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
57
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
143
105
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
107
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
648
