PID programming
tkswathik
Jan 2006
hyderabad
Hi everybody,
i need help on PID loops and designing a ladder logic for the same.
The case is that i need to operate a valve positiion based on pressure on either side of the valve and also the flow through the valve.
can anyody help me in exp the procedure.
swathik.
Most PLCs ahve a built in PID function that you can call from ladder logic without writing your own.
On the physical side, I don't think you will be able to control both flow and pressure drop through a single valve. What is your system doing, and what is the objective?
Maybe he meant he is measuring flow by comparing pressure signals on both sides of a valve?
He may need help with the calculations to convert these two pressure signals to flow. I've no experience here but isn't that possible with a consistent product?
If it is, he could then use PID just to control flow.
I am using a 4-20mA signal from an RTD to an ABB ACH 550 drive. I want to know if anyone has ever set up a PID loop on one of these units before...
1,127
Good Afternoon Everyone, I hope you can help me with a problem. I have been converting a program from a Micrologix 1400 over to a S7-1200 PLC and...
5,344
Folks, I would like to get some ideas/suggestions on how to use PIDE/P_PIDE in best way for my H&V system. I have one feedback: Temperature...
22
5,614
I'm having trouble programming a PID loop in 505 workshop. Are there any examples out there of how to program this, or how it even works? I got a...
1,497
Hi, I am looking for program examples for Mitsubishi L-Series PID programming. I especially am wondering how to assign variables/devices for use...
2,554
