PID setting in temperature controller
ssana168
Jun 2011
Pakistan
38
Dear all,
I need to know the manual setting of PID parameters in temperature controller.
Usually i used Autotuning function to set the PID parameters automatically.
The results of autotuning is given below,
P= 5.2
I= 356
D= 89
I have set the control cycle=30 second to avoid fast switching.
In these conditions i observed that when present value is 144 while setpoint is 150 degree centigrade, than it signals On for 10 seconds and Off for 20 seconds.
After completing 2 control cycles in this manner the present value remain at 144, so the temperature controller increased the On time to 11 seconds.
These all my observations and need to know about manual setting of these loops.
Well maybe, it depends on what P stands for.
If P stands for proportional band, increasing its value will make the tuning less aggressive, more sluggish and will decrease the output's on-time interval for any given error (in comparison to the smaller value).
If the P stands for gain, then increasing its value will make tuning more aggressive, less sluggish and will increase the output's on-time interval for any given error (in comparison to the smaller value).
Hi all, I am having some difficulties with PID controllers, in particular writing the set point via HMI. I am using RSLogix 500, CCW and I have a...
2,524
Background: PLC AB 1756-L61 v13 redundant via SRMs I have a thermal refractory furnace which allows excess air to enter the process to quench the...
2,603
spefically, its the allen bradley free version and/or the 500 version. for the PV on PID, does the input go there or the scaled value? I cant...
1,886
Hello all, On occasion, I need to manually set a PID control variable's initial output when the process is first started- say a bump to 100% to...
3,632
Below is how I set my PID LoopUpdate time, feel free to make suggestion or comments. The PID loop is used to regulate water back pressure. Since...
1,253
