PID Temp control
hounddog
Jun 2003
79
Could someone explain how to use a Analog//Digital option card with a omron plc to control a I/P controlled valve, such as a steam valve.
The temperature is controlled by how much pressure tranducer senses the presser is.
The best option is to use and anologue input from an RTD or themocouple, an analgue output to drive the proportional valve with 4-20ma or 1-5volts and the PID function. Just set the value of the temperature that you want and put the PID function into "auto tune". It will do it all for you.
beerchug
Is the temperature the variable that you are trying to control via pressure if so have you considered cascading the two loops, its a very simple operation but we would require a bit more info.
Regards
hot water control for temperature
actually want to control a valve that would open to allow hot steam or water to flow through a heat coil, as the desired temp is reached the valve be closed off just enough to maintain the desired temperature or open just enough to allow just enough steam or hot water to flow if needed to increase the temperature
Refer to my previous answer. If you are using the CS1 or CJ1 they have an autotune bit you can turn on for the PID function. When tuning is complete, the bit turns off. Could not be easier.
beerchug
Howdy, We have control valves for temp control that need to maintain t- 2 degrees the valves are on/off. The set point and real time temp in G15...
3,783
If you were going to go down to the closest overpass or homeless shelter to hand pick a person to install, program, and tune 1/16DIN panel PID...
5,795
I'd appreciate hearing opinions and experiences of going from discrete controllers to PLC control of temperature. We use a lot of Watlow and...
5,999
I am looking to control an electric smoker with a PID controller. Ideally the heating element would need to be controlled to a set cooking temp...
6,791
Does Anyone Have A Successfull Temp Control Routine Using Pid Tpo For An Ab Micro 1500? I'm Looking For Upto 12 Loops. Or, Refer Me To Some...
3,532
