PID Temperature Control
yakuzaturk
Mar 2012
tehran
Dear friends
I'm working on a project to control the furnace temperature.
As you see in the attached image,The operator enters the parameters(t1,t2,t3,t4,t5,t6,t7,T1,T2,T3) with a siemens hmi.
I want to use the PID temperature controller block of SIEMENS S7 PLC for my temperature controls.
PLC with thermocouple feedback must command to three SSR for switching the heaters.
Can anyone help me?
Honeywell's PAC has a setpoint programmer function block that feeds a setpoing into a PID block, as shown below. Does the Siemens have anything like that?
Just reminding y'all it's a total embargo. Hardware, software, money, advice: everything. It's Federal, and it's inflexible.
Your question is very open.
What kind of S7 plc is it? 200? / 3-400? /1200? /1500?
Don't you find a suited standard PID-control FB?
Are your 3 SSRs controlling 3 equal elements?
Or is it problem with the setpoint scheduler?
Kalle
Kalle
I use plc s7-300 for this project but it's possible for me to change with another one.
I need one PWM pulse for turn on and off 3 SSR (actually one command for all).
3 elements connected to 380 volt with SSR in star connection.
The operators must enter times and temperatures and then start the process.
I don't have problem with HMI software. My main problem is : I'm amateur with using PID controller.
Which FB solves my problem? How I use this FB.
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
649
I have PID temperature control which will connect to Beckhoff EL4004(0v-10v). How I can program it to let EL4004 to control the temperature?
2,649
I'm doing PID temperature controller using PLC. I'm doing a cascaded P, and PI controller of both temperature set points. My question is how...
1,759
go to work on this again this morning. I have attached the file and have a question that i can not figure out. When monitoring the temperature i...
3,550
Hi Everyone. I have been reading through the forums, and I have learned a lot! I do have a specific question that I couldn't find. I have a...
5,131
