I have a process i need to control using PIDAT. It is a simple tank being filled with water controlled by a level valve(0-100%) and a flow valve(0-100%) and 2 transmitters telling me flow in %(0-100%) and level in inches (6-27 inch)
I do not understand how the PIDAT works, i've been looking online to find instructions and example help, nothing works. What is confusing about the PIDAT, is the parameter. I don't know what half of them mean. The manual for CX programmer gives only a brief explanation. Could anyone give me an example? or explain how the numbers i have would be included in the parameters?
Also how does it work with output? because i have 2 valves i need to operate at the same time, would i have to use 2 PIDAT function to control both? or can i just control both with 1 PIDAT
Thank you in advance!
