pilz pnoz m1p ETH to ABL35 communication
I hope you're talking about a L35e CPU...
In your I/O configuration you add a Generic Ethernet Module.
In the pop-up you have fill in the IP adress of the Pnoz Multi, and the connection parameters.
These parameters are: Input 100 size 20, Output 100 size 20 and Configuration 4 size 0.
I'm not sure if there is an EDS file for this PIlz today, but this is how it works in our factory.
Jack
Hello,
I'm trying to connect a Pilz PNOZ m1p ETH with a AB CompactLogix 1769-L33ER.
I tried to use your solution, but the connection doesn't work.
What kind of data are you using DINT, SINT, INT?
How many bits I must set in the Pilz Config Internal Port? (24,128)
Thank you
Lorenzo
Well, it is what I done.
In the images there are my configurations. I think that all is correct.
The CPU gives me the error N° 16#0204 (Timeout connection).
If I make a ping to the Pilz, it responds.
Have you got any other idea?
But are you using an mc8p interface?
Dear All. I need comm between Compactlogix/Controllogix with PNOZ m1p ETH. What we need the communication option? or can be connect direct? many...
1,186
Hi, Dear friends. in my PILZ PLC PNOZ m1p FAULT indicator is ON, PLC not running, i downloaded demo software from PILZ website. it has one D...
6,373
Hi All, I'm currently working on a project where I have to set up ethernet comms with a Pilz PNOZ Multi M1P Eth from AB L72 PLC. I have it...
5,062
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
522
WANT TO KNOW ABOUT PILZ PNOZ S3 WIRING & FUCTIONS:teacher:
1,819
