Place SM335 in rack?
jens92
Feb 2013
Sint-Truiden
Hello,
I wan't to use an analoge output for a micromaster 420. I found the SM335 from siemens here in the company. But when i wan't to place the module in my rack, I can't? Can somebody help me? How should i configure the SM335?
Hello,
In what system are you trying to install SM335 module?
SM335 is for a S7-300 system
You can find the manual for SM335 here:
http://support.automation.siemens.com/WW/view/en/1398483
Hello jens;
How exactly do you have a problem inserting the module?
In the hardware configuration, can you find your SM 335 in the catalog of S7-300 modules? If you do not see it, please give us the version o Step 7 you are using. The UPDATE document or the SM 335 shows that with Step 7 5.3 and a HSP you should ind it in your hardware catalog, and with any later version also; see the following links:
6ES7335-7HG02-0AB0
SIMATIC S7-300, ANALOG MODULE
Updates New SM335 Fast Analog Hybrid Module Released for Delivery
Reqired Step 7 version: HSP2043 V1.0 for STEP7 V5.4 SP3
Hope this helps,
Daniel Chartier
Now it worked. I used the module out of the ET200. But you can also find the module somewhere else.
And I don't have a profibusconnection on my micromaster..
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
77
I am very, very new to PLCs. I only have experience with Picos, but I knew enough to save this from the dumpster. Apparently, everything on it is...
625
Can we use an output reactor in place of an input reactor ? Are they physically similar ? Because we have faster delivery on some chokes .
841
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,266
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,595
