PlantPAx Flow Control Valve Setup
zackscriven
Sep 2017
Rancho Cucamonga
Hi! I am programming a control system using Control Logix and we have standardized on the PlantPAx Library for graphics and control.
I have a Flow Control Valve that is going to be controlled with a PID loop.
The Flow signal will be the PID PV
The Valve Position will be the PID CV
What am I to do with the other Valve Signals I have? Fully opened, fully closed, ready, and fault?
I can't use the P_ValveC because the analog position control is used in the PID. Should I use a P_ValveHO?
Any help is much appreciated. Thanks in advance.
-Zack
-Zack
You should be able to tie the P_PIDE.Out_CV to the P_ValveC.OSet_CV (or .PSet_CV) and then you can tie your LS into Inp_OpenLS/Inp_ClosedLS.
You valve position output ties to P_ValveC.Out_CV
P_ValveHO is for a hand operated binary valve.
Hello, i need to use P_Intlk and feed the Status interlock OK bit to a P_DOut block. However, there's 17 interlocks for this output. How can I...
109
Hello All We have 3rd party vendors that run on older versions of PLC (Plc2.0) while we run the main system using plantpax and PLC 3.5-10. Plantpx...
96
Dear Members, Hello, we are working on a project and facing an issue with the plantpax 5 PMTR library, we have a bidirectional motor, which has 2...
248
The PMTR has a timeout parameter for run feedback during a start, but once the motor has been running for a while and loses that run feedback (to...
225
Hello, I am upgrading some custom AOI's for a customer that was using plantpax 3.5 they are moving to Pax v5. In their old AOI's they were...
536
