PLC-4/40, SFC Stored Action Overlap
Josh.L.D
Aug 2015
Grimsby
I’m having a problem swapping out a plc-5/40 1785-L40E series D revision A for a revision L.3. Rev A has been running fine for years, but now its faulting and loosing its memory so it needs replacing. The last unit I have is a revision L.3 so I downloaded the existing program onto this processor and when I put it into run it faults.
The fault code is 47 which is a “SFC stored action overlap”. I couldn’t work out why this was not a problem before, then I found a write up on the Rockwell website stating that this fault was a minor fault on the Rev A and its has been changed to a major fault for all revisions past B.
So now I understand why this problem has developed but I cannot find the fault in the code to correct. The processor status file states the problem is in file 4 (my SFC file) on rung 17 (SFC have no rung numbers).
Has anyone got any ideas/ advice?
Welcome to the forum Josh.
Its been ages since I used PLC/5 SFC, but I suggest that if it worked before, then intentionally reset the fault bit before the end of the scan.
Q(1) Design a controlling system using DVP-40ES Delta PLC for a threestory Elevator Prototype as shown in the figure below. Show in details the...
2,180
I haven't done much with SFCs so I am trying to make sure all my bases are covered for a recent upgrade (and SFC conversion) I did from a PLC-5 to...
1,341
I admittedly have used SFC very little over my career so far, but need to convert a PLC-5 program which has a decent amount of SFC code to Logix...
2,150
Dear Sirs, I have no doubt, they only seem retarded because I lack understanding of them. I'm having a good time building up circuits and using...
2,132
I have a program that currently runs in SFC on PLC5. Can i add jsr into one of the routines that are always scanning? I never worked with sfc much...
1,726
