PLC 5/11 Comm errors.
showshocka
Mar 2011
USA
510
Hey guys. I'm having a problem logging on to a PLC-5/11. At first, when trying to log on I noticed a flashing red light at channel 1A status indicator. It has turn back to green now, but I still can not log on to the PLC. It is up and switched to Run mode as usual. Here is a picture to see what's going on. In the picture, the Communication Screen is flashing between 2 errors for the device...
Well it's hard to read, but chech your device type in the DF1 driver config. page. It look like it's set for a SLC.
The Autoconfig isn't completing, which is why you still have "SLC/MicroLogix" as the Device Type.
DF1 Autoconfigure frequently has problems with USB/RS232 converters (you're using COM3, which makes me guess you have one). You can hard-set the DF1 data rate and device type and try to browse using the settings you think you have in the PLC-5/11.
The PLC-5 default is BCC error checking, and the default baud rate changed over the years; it was 1200 a very long time ago and changed to 19200. The actual correct baud rate depends, of course, on the configuration in your PLC.
A flashing red LED on the DH+ port suggests some physical errors or even a duplicate node address. I would solve the DF1 port connection first, then do some diagnostics on the DH+.
Channel 1A on a PLC-5/11 is usually configured for Data Highway Plus communications (DH+).
If your PC is connected connected serially,as per jkerekes'sd answer, use a DF-1 RSLinx driver targeting a PLC-CH0 device(not SLC/Micro/PanelView)and use the Auto Configure feature when defining the driver.
If this doesn't do it, there is probably an issue with the PLC's Channel 0 communications port.
In this case, another option will be to try to go Online with the controller using a DH+ RSLinx driver such as 1784-PKTX(D)/PCMK, however, this will require a suplementary PC to DH+ interface(PKTX, PCMK or a 1784-U2DHP USB-to-Data Highway Plus Cable with an 1784-U2DHP driver) wired up within the PLC 5's channel 1A network.
I suppose we should take a step back.
The PLC-5/11 was a New Platform PLC-5 controller, so it has a 25-pin Channel 0 RS-232 port. That's what you should be connected to with a serial port (built-in 9-pin or USB/RS232).
Channel 1A has both a 3-pin "Combicon" connector and a Mini-DIN8 round connector. These are physically connected together and are a DH+ port.
I don't know if Channel 1A can be reconfigured for RIO on the PLC-5/11.... I would have to go dust off a User Manual.
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
529
Last night electricians replaced the panelview and now there is no comms between the panelview and the PLC. The processor is a 1747-L541 SLC 5/04...
906
I've been given a line that has several sysmac c200Hx PLCs. The First station Im trying to wrap my head around has a NS8 HMI. I'm using Cx-one...
752
Hi, I'm working on a project with an Allen-Bradley PLC, so we are using Studio5000. I have a bunch of things that communicate through ethernet/Ip...
1,255
Hi, Please I need your advice. 1. Master PLC Mitsubishi CPU-R04CPU + ETH module RJ71EN71 2. Master need to comm with AB CompactLogix 1769-L33ER &...
2,351
