PLC 5 in Hot Backup
ashley
Jun 2002
Perth
58
I am troubleshooting a PLC 5 hot backup system in which the switchover is not taking place. I noticed that one PLC 5/40 processor has firmware revision K and the other revision H. Is this an issue for hot backup? Do both the processors have to be of the same revision? Any inputs on this will be appreciated.
I am facing a problem with PLC-5 connected in controlNet hot back up redundancy.This PLCs are connected to a RS view 32 running HMI.After a power...
1,988
I know you can change out ControlLogix cards with the rack powered. And I thought that you could not do it with a PLC-5, but a colleague at work...
4,182
I have a setup which communicates as follows: Wonderware InTouch HMI . . Kepware OPC Server . . DirectLogic 06 PLC (local) . . The Internet...
1,600
RSLogix 500 v9 OSR storage bit & output bit I am programming a sonic welding generator and I am stuck on an operation I need to perform and I'm...
2,251
Folks, We have a black-box provided by a vendor that we maintain. Inside the box, there is a Modicon TSX Micro 3722 PLC. On the front panel of...
6,886
