PLC 5 Upload Failed
It most likely is a PCCC protocol issue related to the CPU memory.
You might be able to find another .RSP file which RSL5 will upload into, however, you will eventually have to download to the processor a good backup file in order to mitigate the problem.
Use the RSLinx Classic (any paid for copy- Not Lite!) Tag Upload Download Tool to keep the data tables values current.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/32503
Access Level: Everyone
I believe this is what dmargineau is referring to...
54710 - RSLogix 5: Upload failed - Command cmd 0xF, fnc 0x69 failed Ext Sts = 0x07
Access Level: TechConnect
Regards,
George
Hello members, I have Siemens S7-1200 PLC (CPU 1214C AC/DC/Rly version 3.0) and I want to get backup from it. I know how the procedure works. I...
150
Hello, I have a machine with a 1756-L72 Controllogix PLC and 1756-EN2T network card, and PanelView Plus 7 HMI. I am using RSLogix V20.05.00...
929
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
351
Good morning to all, I need to modify PLC configuration adding a new Profibus card. I've an issue during upload of actual configuration. With my...
601
