PLC Analog Input/Output Modules
alanyap
Jul 2014
Kuala Lumpur
72
Hey guys,
I'm with control Engineering background, working as a plc programmer.
Recetly i'm interested how an Analog I/O card works...
I wanna study about how the conversion is done from the signal to the raw value coming out of the address from peripheral input.
Any leads to the architecture or the operation charts for me to understand more about the conversion etc??...
Is there any different between the brands of the PLC that effects the conversion? eg. (between OMRON & SIEMENS)
If there any related threads please feel free to drop the link here!!
Thanks!!~
đź“šđź“šđź“šđź“š
Hi all, I’m an electrician with limited knowledge of PLC circuits. Typically I will see simple 2/3/4 wire terminations for transmitters on...
26
1,293
Hi all, I want to catch min piks of an analog signal when digital signal is on(pls see the attached oscillogram). My hardware is 5069-L306ER CPU...
1,014
Hello I have a analog input signal that is bouncing a bit. The PLC card is a 1769-IF8 I changed the input card filter setting from 60hz to 50hz...
4,906
Dear all I am using delta AH530 RS- 2 cpu with devicenet communication and now I am getting problem while configuration of AH6xa-05 which is...
1,054
Hello everyone I got problem during practical. I am using delta plc model:DVP20EX00R2. Problem is that when i give 7v dc supply through bridge...
2,458
