PLC and Windows 10 Hybrid
sparkie
Nov 2014
KS
1,148
So I was reading up on a new compactlogix and windows 10 hyrbid PLC. I feel like one of the benefits of using a PLC and computer based system is that with a PLC it has a specific purpose it is built for. That purpose is to examine the state of various virtual and physical inputs and turn on outputs based on the state of those inputs. The purpose of the HMI is to control, analyze, record and distribute the data from the PLC.
This is similar to some stuff from beckhoff where they use automation PC's, but it kind of gives you the benefits of both worlds, however it seems that if you have to work on the "Windows 10" side of the hardware you would have to take the PLC down anyway, where you can swap out most HMI's without interfering with PLC operations.
You can also run full-blown PC based HMI's on hardware like enterprise servers and use virtualization to distribute. I'm curious to hear the take from you guys on this situation. The other benefit is that IT based system redundancy is quite effective.
Regardless, this side of automation is changing. The relationship between controllers and HMI's.
Hello All I have an older machine that has an existing Electro Cam PLS. I want to look to replace this system and add an encoder to capture the...
2,215
Hi! I would like to rename a document (pdf) in Windows with a variable from my PLC. I'm using a CompactLogix PLC with FactoryTalk View ME...
2,068
Hello, we have several ex100 PLCs and a T2 PLC. We have the old DOS Software for the ex100's and an older Win 95 Software for the T2. My question...
1,494
Hi! first of all say hello and thanks to all the community, I just bought a laptop with windows 8.1 x64, I used to use ibapda V6.24 on windows 7...
5,055
Hi all, I am using a Compact Logix 1769-L33ER PLC with RS Studio and Factory Talk View software to develop a protection and control system. It...
3,920
