PLC back up
basoenek
Oct 2007
Port Harcourt
I am A new PLC user.Can someone please tell me in simple detailed steps how to back up a plc.We use an Allen-Bradlley SLC 5/04 CPU type of plc.
I will appreciate if i can get immediate answer.
Are you taking a test right now?
If you have a program it's backed up. If any value's (timers,counters and so on)have changed you need to go online and save the program and upload last state and value's.
You need version of RSlogix 500/Rslinx that recognizes the version PLC and a method to connect to the SLC 5/04 either serial , with DF1 cable, or via DH+ usually with a PCMCK DH+ PCMCIA card and cable
and... you should have a copy of the program 'with comments', if you want your comments or you will just get the rungs and I/O's without any descriptions... Thats a fun way to test how good you are :)
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
161
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
94
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
92
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
62
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
101
