PLC Communication Failure Timer error
Carlos V
Jun 2007
George Town
17
Hi everyone, I am using RSView32 and last week the computer that was running it crashed due to thermal failure. I have gotten a new computer and I can open up the RSView32 software however I keep getting the following alarm PLC Communication Failure Timer. I believe it has to do with the heartbeat timer to a specific plc timing out. I think this means that there is no communication between the plc and the computer. I am also getting a error message at the bottom of the screen that says : write to tag HB_to_OCP_5_pv has failed. OCP means Operator Control Panel 5. II am new to RSView32 so as you can see I don't know what to do. Can someone please shed some light on this. I used RSLinx to check to see is all the drivers were configured and everything seems ok.
Any help would be greatly appreciated
Carlos,
"write to tag HB_to_OCP_5_pv has failed" most likely means that your RSView32 program is not communicating at all with the PLC.
After reloading RSView32 on a new computer, you must go to Edit Mode and set the Node and Channel. Otherwise, RSView32 does not know where to look to find the PLC.
One remote DP interface (IM 151-1) module of S7 PLC system going to stop suddenly. It is the farthest end.That module is supplied by a power...
2,902
Hi All, I need to dispaly an alarm whenever communication link between Simatic multipanel HMI and GE90-30 PLC is failed. There is a system...
5,546
175
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
183
Hello We have installed several G.E. Fanuc 90 70 PLC Everything was ok but suddenly we can not communicate anymore with any PLC with the software...
97
