Plc For Simple Machine
32racer
Dec 2004
I am new to the plc world but i am currently bulding a pretty simple automatic machine that bags clothes in cleaners. i have been installing a german machine for years and they use a moeller plc on them. i am looking for a relativly inexpensive plc that will run this machine. the machine will have approximately 9 inputs and 12 outputs. it will basically control air valves and a 1/4 hp gearhead motor.can someone please tell me what a good unit would be to use on this machine? what would a basic unit cost? i need one with a lcd screen. thanks 32racer
If it's working, you could just stick with the Moeller. They are available in the states. The MFD Titan has a screen with buttons to allow inputting of values etc. You can check it out at: http://www.moellerusa.net
*disclaimer* I work for a Moeller distributor. (and proud of it :D )
Siemens
You could also Siemens S7-200 and if your program is very simple you can use LOGO. It's a modular programmable relay, but you can rech 24DI, 16DO and AI (only for comparations).
Forgoselo
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,049
Hi, I have setup the Simple PLC communication in RJ71C24 (Channel 2) for communication between Mitsubishi IQ-R series PLC (Mosbus RTU Master) and...
2,532
Hello everyone, I am a newbie in automation stuff and i wanted to do a simple thing with just a sensor, a blade and a plc. My aim is this - The...
3,987
Hi, I am currently working on a little project and I am wanting to control a fans speed with some PLC digital outputs / anolog output but unsure...
3,453
I have two AB MicroLogix 1500s that I want to be able to communicate with each other via two Transnet 900 radios (one master, one remote). Using...
1,601
