PLC Input/Output Devices
monkeyhead123
May 2007
Cardiff, Uk
I'm trying to research a few input and output devices for a PLC.
I've managed to find a couple of Input devices, such "XUJ Thru beam and retro reflective Sensor" and "Miniature bearing temperature sensors".
However I cant seem to find anything on output devices for PLC's :unsure:
Is there any online catalouges,websites that anyone could recommend that would help with my research.
Many thanks
Matt
Just to get you started, the following devices are a small selection of things that could be connected to PLC outputs ....relays, contactors, indication lamps, solenoid valves....
You just have to make sure the voltage and current rating of the output device matches that of the actual output.
The output device is going to be whatever it is that you are trying TO CONTROL!
You tell us.
Are you trying to open flow of material through a valve? (Then you would need a "solenoid".)
Are you trying to make a motor go round and round? (Then you need a motor starter, contactor, or contact closure to a drive.)
Are you trying to tell someone status of something? (Then you need a pilot light.)
Etc. Etc.
Hello everyone. I have a question about Rockwell PLC communication. Now I have a PLC5/30 and a Guardlogix 1756-L71S rack with 1756-DHRIO In my PLC...
1,421
I need one PLC to receive a signal from another PLC. Can I wire the PLC output of one PLC to the input of another PLC? (same voltage of...
3,940
I want to push a button going to one s7-1500 and have it turn on an output and turn on an output on another networked S7-1500. The local part is...
2,127
Hey Guys, I am wondering if it is possible to wire an output from PLC to the start enable terminal (2) on the powerflex 40. as far as i can see...
1,696
Hello everyone I have a Siemens S7-300 CPU 315-2DP, CP343-2P and ASI module .AC2459 I want to using it for test input output . as show in below...
18
4,282
