hamzasyyed
i need to interface a siemens PLC(300series) most probably 314ifm, with a HMI(LCD screen) and a personal computer for data aquisition,
now the problem being cost, and me not being able to buy modules and cards(which cost a lot), that is why im using the 314ifm which has integrateed analogue inputs and outputs.
now i understand that the interfacing can be done through MPI port, but there is only one MPI port available in the 314ifm, so either i can interface it with the PC(personal computer-desktop) or the HMI.
so here is what i was thinking interface the PLC with the PC directly and then interface the HMI with the PC, so i can aquire data on the PC, and then display that data on to the HMI.
will this be possible? if so which HMI will i need to use, a siemens one/can some other be used?can the data be displayed real time?will control be possible through the HMI(inputs to the PLC) or will it only display?
also are there any models with 2 MPI ports in the processor itself? the maximum cable length of the MPI,because my PC will be 70 meters away.
