PLC Interfacing
kxs436
Jan 2011
Boston
43
Hi All,
I am planning on proposing the communcation schema for a project as in the atatchment- bascially a SCADA which is connected to the internet. My question is if it possible to connect DCS to the SCADA (shown in the atatchment) via internet. And what is needed for the interface.
thanks
Karthik
Depends on the SCADA, the communication drivers, and the DCS. Generically, the answer is yes - we would have to know a whole lot more about your system to be able to give you an exact answer.
Dump the hub
I would highly recommend not using an Ethernet hub, instead use at a minimum an unmanaged Ethernet switch. Due to the fact you will be going out to the internet, you may want to have a managed switch and/or a router so you have have better control.
Greg
hello i want to read temperature data from Masibus UT94 temperature transmitter which is giving data on RS485 port. i have assigned ID:-30 and...
1,075
hello, Can anyone help me regarding the logic of interfacing ELITE 440 energy meter with M200 PLC over Ethernet. Elite 440 is having Ethernet...
3,861
Can somebody help me with interfacing of Schnieder EM6400NG multi function meter with m340 plc using modbus. i want to read KW (Power) of load.
1,660
Hello All, Is there anyway of directly interfacing the Maxim 1 wire protocol to a PLC? Thanks Carl
2,283
Hello, I intend to connect to a ControlLogix 5571 PLC through a work station and program it. One way is to install the RSLinx driver and then use...
3,634
